C100: How long does it take to charge Ninja Blade batteries? Need asap answer
nedcam
Hi Guys,
I rented a Blade and can't figure out how long it takes for a couple of batteries on the charger to get full up. Anyone know? Manual doesn't say. Got a gig in the morning and need to know if I have to wake up at 3AM to change batteries on the charger.
Thanks,
I use the LP-E6 Canons and they take about two hours each, I threw away the Sony style batteries that the Blade came with, I don't use Sony batteries, I have a dozen of the LP-E6s, they are cheap and work well. Good luck.
It does depend on the charger, the atomos charger is quit slow so 2 to 3 hours is to be expected
i use sony n/f style batteries and...it does take some time. I'd say 3 or 4 hours for the littles ones and 6 hours for the big ones !
also, careful on the charger, sometimes you have to pull and push again the battery to the end of the charging slot because the battery looks green (charged) and its not. These atomos chargers need to be checked a lot (plug, slot..).
