how does 60D compare to 7D in low light???
I've been looking on Vimeo, but haven't found much yet regarding the Canon 60D's performance in low light. The reason I'm asking is that I'm having a tough time trying to decide between buying the 60D or 7D.
The 60D's articulating LCD screen would be a huge plus for me.
But I hear that 7D is better for low light (5DM2 way out of my budget).
Can anyone who has used both, please tell me what your impressions are regarding the 60D.
For example, with a lens like the Canon 35mm f/1.4, would there be a noticeable difference using the 60D in low light over the 7D??? Or is that lens so good, that you would not notice any more noise on the 60D in low light at f/1.4 than you would on the 7D?
Thanks in advance for any feedback.
Can't see any reason why the 60d would be different than the 7d, I don't thing the 550d is different either for that matter. They all use pretty much the same sensor after all. If any would be better it might be the 60d if cannon have tweaked the sensor in some way.
Regarding the lens, the sigma 30mm 1.4 is worth a look at 1/4 of the price of the cannon. Its sharp enough for video and just as fast. Of course, it is not compatible with full frame cameras, and the 35 1.4L is an amazing lens on a 5D.
Shouldn't be any difference between 7D & 60D, as they have the same native iso's (as well as the same sensor as mentioned above) but the T2i does *not* have the native ISOs and so has more noise depending on which ISO you choose. There's a series of comparisons between 7D & T2i/550D somewhere on these forums illustrating this with low-light test crops to show the difference in noise between the different ISOs.
There is a difference between the 7D and 60D in low-light. Yes, both cameras have a DIGIC 4.... however, the 7D has a DUAL DIGIC 4, which provides better low light performance.
Also, not sure if the true native (sweet spot) ISO has been determined for the 60D. The 7D true native iso is 160, 320, 640, 1250, 2500, I believe.
Wrong, dual digic4 has nothing to do with low light performance, they are the same, I have both.
I also own both -- as well as the T2i. I've owned them all for about as long as they've been out.
A Dual Digic 4 (vs. single digic 4) helps out in a variety of ways -- two of the main ones are FPS and ISO performance. I've confirmed through my own tests. Put the same lens on your 7D and 60D. Go into a room with low light. Crank your ISO up to at least 2000. Use the same lens on both cameras (I used my 17-55 f/2.8). You WILL see the difference. Heck, I didn't even need my enormous iMac screen to see the difference in noise. I could see the noise difference on the LCDs.
If you're shooting in normal ISOs (160-1600), you won't see a difference in video mode. In the rare cases you might have to crank it to 2000+ (which you shouldn't do often) you WILL see the difference. Why do you think huge production crews are starting to throw a 7D in their lineup along with $50,000 cameras and NOT the T2i (which has the same sensor as the 60D)
Just sayin....
probably build quality and the fact that it can output full HD while recording.
I don't think any production crew would use DSLR video at over 1600 ISO, and even then probably not there....
For practical purposes, I'd pick the 60d over 7d any day. I've shot the 7d and without external monitor, your low or high angles are a a pain in the butts to shoot if not impossible. The articulating lcd of the 60d is what I've been waiting for. As for low lights, unless you're a picky guy who looks for every little grain or noises, 60d is just as good as the 7d. It's a matter of how you use it. But than again, in a couple of years times two, these two cameras will have been out of date and out of style, if not obsolete... that's my 2 pennies worth of thoughts.
I totally agree with you Pathfinder. I also have the 7D and wish I had wait a bit longer and bought the 60D instead. You mention the articulating LCD, but manual audio on the 60D is another huge advantage.
I prefer having the HD signal during record on the 7D. An articulating screen is nice, don't get me wrong, but when my camera is up on a 12 foot crane, that articulating screen is pointless. In addition, I use my camera a lot on the end of a monopod and extend it way into the ceiling or running it across the ground. Having an LCD close to my face has been much more beneficial. I use a smallHD with the HDMI out and it is GREAT.
Personally, if I were buying today I'd probably go with the t2i if I needed something immediately OR wait for the GH2 that is supposed to ship in November. Having used the 7D since it was released, I CANNOT STAND the rainbow moire and aliasing. The 60D doesn't fix this either. It also appears the rolling shutter performance is the same as well.
I really wish that Canon would make a newer sensor.
The t2i isn't bad, for the money. The lack of kelvin, though, drives me mad. Especially when using a two- or three-cam setup and trying to wb in post.
We've used a t2i for a few shoots and I will say, the LCD on the back is MUCH better in my opinion than the 7D, 5D or 1D, all of which I have used. I don't do any of the color grading in our projects so I guess I've been lucky :)
Really the only thing that has kept me from a GH1(3) is no one has made an electronic mount so I could use my EOS lenses on it. Now that Birger has announced one they are working on that they claim will be out before the AF100 ships, I've pre-ordered an AF100.
Were I not getting the AF100, after seeing a bunch of the GH2 footage in the wild now, I would have SERIOUSLY considered this camera instead of the t2i or 60D.
The other problem I have with the t2i is it is too light! :) I have to add weight to my 7D on a steadycam setup (I use the blackbird) because more weight on all those systems just works better.
Just sayin....
Your out of your mind......... Please stop making things up
The only thing I could imagine the extra Digic processor could do is perform more aggressive noise removal AFTER the image is captured from the sensor. Which means you can do this yourself with a plugin like Neat Video on the 60D if you are so inclined. To truly test the native ISO and noise, one must turn OFF the noise removal. We don't know if they are the same algorithms.
It's the same argument with sharp/soft. It's hard to know how the image looks once it is post-processed in camera with different algorithms.
And of course, the old saying goes, pictures(video) or it didn't happen! :)
