Magic Lantern has Kelvin white balance.
I generally use the auto cycle and then adjust it to whatever looks right if needed.
But, is there a way to find out the correct Kelvin temperature of the light? So, if I use lights and if I have to match it to other light sources, they are all the same.
Most of the time the auto mode is not right and I have to adjust it manually, but when I do, I can go through thousands of degrees and it will look the same or so similar I wont see a difference. I want to get the correct settings each time.
