justmarvin
How do I downgrade resolution? DVX100b "THIN" mode. Flicker artifact on SD b/c hi res
I heard that you would get a flickering artifact when you play footage shot on "Thin" mode on the DVX. I shot on "thin" mode because it gives the most resolution and the project I shot "might" play on the movie theatres and I heard thick mode isn't good for projection on a huge screen like that. So I shot thin, and I heard that I can always downgrade the resolution in post production. But my question is how do I do that? And what exactly do I need to do? What resolution do I need to set it at to play the best on an SD tv screen broadcast (and how do I even downgrade the resolution?). I edit on an Avid.
Thanks!
JM
PS: If high res causes a nasty flicker artifact on SD screens... what about the HVX? Isn't that using high resolution, and does that mean that shooting on an HVX wouldn't be ideal for SD broadcast?
Thanks!
JM
