JaredSMark
As far as I understand it, on a macro scale, your camera saves a frame once every 1/24th of a second if you select a 24FPS frame rate. The frame capture times are evenly-spaced throughout 1 second and are always saved at that interval (1/24). That's as far as I understand it. The electronic shutter seems a bit more complicated though.
So again on a macro scale, does the electronic shutter (sensor) just 'pulse' on and let that frame be exposed for however long you've set the shutter speed to, then turn off and wait for the next frame interval?
I know it's a bit more complicated than that because it saves/scans the rows of pixels in a certain order or something like that, but I wanted to clarify.
