Question on best format for a particular situation I'm faced with:
I'm going to be doing a project in Thailand with a HVX200 NTSC model. The final product for the client will need to be a DVD playable on PAL TVs. I want to shoot HD so that can evetually produce a high res version of the the video.
I would like to shoot to p2 cards in some form of 720p....Which HD format would be best for my needs... of being able to playback on PAL TVs as a DVD? I'll be shooting mostly talking heads -- Is it better to shoot 720/24pN or 720/24P or 1080/24pA?
I can only afford to do the downrezzing using software and a macbook pro.... should I be using FCP alone or should I be using FCP with Nattress plugins to do the conversion appropriate for DVD...? or should I edit in HD in FCP and then convert in compressor? Do I need to use Nattress plugin at all for this job of getting it to DVD playable on a PAL TV?
Or should I have rented a HVX200E PAL version? ;-) Unfortunately this isn't an option.
Thanks for any insights anyone has... I'm getting really confused the more I read the HVX forums.
