Host Mode Questions...
FUBARFilms
I have a few questions about Host Mode on the HVX and I want to make sure I get them answered before I go out and buy a HDD.
1.) Does the HDD need to be 7200rpm or will 5400 work? I know some of the smaller HDDs are only 5400 and I wouldnt want to carry a big HDD around if I could get away with a smaller one.
2.) How do the clips transfered via Host Mode interact with a Mac and FCP 6 (in other words, could you use Log and Transfer as if it was the P2 card in the camera?)
3.) What relatively inexpensive hard drives ($200 or below, at least 120GB) are proven to work well with the HVX in host mode?
Thanks so much!
2 out of 3:
2 out of 3:
Thanks so much!
1) I'm not aware that it MUST be 7200 RPM. I use a WD Caviar SE EIDE 320GB|GO w/8 MB cache @ 7200RPM installed in a combo 1394/USB2 enclosure bought at CompUSA before our local store closed. I'm sure I paid no more than $ 225 in total. I've offloaded via both 1394 and USB2 numerous times to it and it's held up just fine.
2) Can't answer that; I don't use my Mac for editing.
3) Most any known brand of drive should do. Perhaps the wisest recommendation is to make sure the total space = 15 times your largest P2 card.
x
Any hard disk will work; a 4200RPM drive would work.
Exactly the same as they do from the P2 Store or from a P2 Card.
Any drive should work. However we've heard some reports that very big drives (500GB or terabyte) may be generating some sort of "too many targets" error. I haven't tried a drive that large but I've never found a problem with any drive that I've tried. Also, you have to make sure that you're supplying adequate power to the drive; some people have reported errors with their drive that they can't do anything other than format it, there's no option to copy... and they've solved that by using a stronger power supply. So only use the power supply that comes with the drive.
Thanks so much guys, yeah I just plan to use a small 150 GB HD with the AC power and as long as that holds up fine I guess I should be okay. Thanks again!
Hey guys, sorry but i have one more question...I just picked up a HDD and it can either be supplied by bus power or a separate DC cord thats 5VDC, the guy at the store said I could get a 5V DC at any radioshack, etc.. Would that be adequate to power the HDD so that I could copy files to it?
Good point!
Good point!
I think it's really a matter of the specs for the drive, or the enclosure if you're using one. Check the specs. The combo enclosure for my 7200 RPM drive came with a 120 V A/C ->12V D/C adapter.
Power is the biggest drawback to using an external drive; choices seem to be:
1) being tethered to an outlet for the length of time it takes to offload, (which has been no problem for me personally, but could be inconvenient in the field),
2) a relatively expensive battery that lasts a good length of time, (techeon (?) has gotten lots of praise here), or
3) a less expensive battery that will provide enough power for offloading but may not last long enough to completely fill a drive; you may get a drive half-full or more. That will depend on the amount of data you're offloading, i.e. a 4 GB card will take less time & power than a 32Gb card).
In any event, don't expect a 1394 drive to receive power from the camera. The HVX will not supply power to an external 1394 drive.
I'm guessing you got a USB drive, mainly because most bus-powered drives I'm aware of are USB; I don't know of any bus-powered 1394 drives. (Though there may be...I'm just not aware of any, but I think they're trickling onto the market). I know the Citidisk can use both battery and A/C adapter and I'm pretty sure the FS-100 does, too, but both are intended for recording DTE, not for offloading.
Hope this helps.
x
I don't mind being connected to a power outlet, I just want to make sure (before I open the box and before I buy the DC cord) that 5V D/C is enough power for the HVX to send over the files. By the way it is a 1394/USB 2.0 bus powered drive (or DC outlet, of course)
I'm a little confused.
You say:
This may be obvious, but I want to be clear:
Having "enough power for the HVX to send over the files" actually comes from powering the HVX. The camera must be powered, either by its' own battery or via an A/C outlet, for the camera to move the files. Additionally, the hard drive MUST have its' own power source, either a battery or an A/C -> D/C adapter that plugs into the drive.
The 5V cord would be powering the hard drive you're offloading to; it will not provide power to the camera. The specs that came with your hard drive should tell you what voltage is needed to power the drive.
BTW, personally, I think getting a combo 1394/USB drive is the smarter buy, if only for increased flexibility.
Lastly, be aware that USB does not allow file verification during the transfer/offload from P2 to hard drive. Verification can only be done using 1394.
Hope this helps...and welcome to the world of HVX. Good luck with your new "toy".
x
