Horror Trailer DVX100b 24P
I just thought with everyone making horror movies for horrorfest right now that it would be. But since you put a trailer up and we're not supposed to show footage from our movies, I was confused. When I commented, I actually forgot I wasn't in the horrorfest thread. Sorry. I do like creepy masks though, particularly when there partly obscured, like through the window.
Overall, I liked it. The framing on the second shot seemed a little off, and in some places the fog looked out of place.
I saw that you said you shot in 24p and edited in a 24p timeline. If you shot 24p normal, then you should be editing in a standard 29.97 timeline. If you shot it in 24p advanced, then you should be using a 23.98 timeline.
There are two pull downs, which allow us to record 24p. The first is 24p normal. The 24p normal pull down is 2:3:2:3. The reason for this pull down is because in order for us to get 24 frames to fit into 60 interlaced fields we need every 4 set of frames to fit into 10 fields. The pull down works by having the first frame printed to two video fields, and the second frame printed to 3 video fields. The pattern then repeats itself, so every 2 frames get written to 5 video fields. So for every 4 frames your getting 10 fields. This process happens 6 times per second, which leaves you with 60 fields. Because of this pull down you end up with 2 split frames and 3 full frames. So for example, if you have four frames
A B C D your first two frames will look like this: aa bb. But your third and fourth frames will be a combination of two fields, so they will look like this: bc cd. And then your last frame will be a full frame and will look like this: dd. So you can think of the pull down as taking 4 frames and making it into 5 frames. So you have 5 frames, which is equivalent to 10 fields of video. So 10 multiplied by 6 equals 60 fields. Since all of this fits into 60 interlaced fields, you’re able to edit it using a standard 29.97 timeline in your Non Linear Editor.
The second pull down is known as the advanced pull down and records using a pull down of 2:3:3:2. Essentially, this pull down does everything as the normal pull down does to record to tape. However the difference is that because of the pattern it leaves only 1 split frame and 4 full frames. So since the process occurs 6 times a second, you are left with 24 full frames. Using your NLE while you are importing this footage you are able to remove the split frames leaving you with a full 24 frames for every second. So because of that you are able to edit using a 23.98 timeline.
Here are two links which explain 24p very well.
http://www.adamwilt.com/24p/
http://www.kenstone.net/fcp_homepage/24p_in_FCP_nattress.html
I hope this all helps.
Lol thats pretty good for such a short piece of work. I didnt like the skull mask much. I thought he looked wierd enough. Perhaps though in the trailer you could have kept him more of a dark figure then hit us with the wierd face closer to the end with a bit of a flash not let us see it so long to realise its a wierd mask.
Overall did look a tad videoish... lighting was sometimes good, other times ok.
What I liked the most is the color timing, I thought it suited the mood etc very well.
As you said it was for fun, done in 6 hours. Nice!
yep, not working here, i just get a picture of .. i dunno what its called, pretty sure that new nebula is called Verxis.
WhiteWood said:
All I see are pix of a big chick...no trailer
WEll yeah i really wanted to see this but those horrid pics were at the end of the link instead......those pic's will probably haunt my dreams forever!!!!! LOL but yeah what am i doing wrong i want to see this vid and is anyone else having this prob except me and Whitewood and if soo flippin help us!!!
good stuff
You guys are straight wrong. What if that's his girlfriend or something? You could be hurting someone's feelings.
