That was the first thing I've checked. Definitely with normal shutter, no electronic one.Did you shoot this in Silent Mode or with Electronic Shutter engaged?
I try to keep ISO for stills below 3200. Yes, I've definitely pushed it in post, but not to extremes. And even with extremes those lines should not have happened. I would expect uniform noise across the image.What ISO? And did you push the exposure in post?
Looks like an under exposed image pushed in post.
No. Even old Sony DSLR (a350) doesn't have that. Sure it's underexposed, that were conditions I was forced to take the pictures with what I had. What I've uploaded is straight from RAW to jpg - no adjustments. The problem is that with nonuniform noise even after noise reduction in post it's almost not possible to save the picture. It makes lines more visible and it looks bad. Of course it's going to be soft with NR but being uniform it makes it easier to "accept the shot".Doesn't every digital stills camera from every company show lines like that if pushed far enough?
... Sure it's underexposed, that were conditions I was forced to take the pictures with what I had...
If you used Lightroom to do this, some adjustments are automatically made, including sharpening, and other color adjustments. I think the issue is underexposure as many have said. The GH4 is best exposed to the right to reduce the amount of noise in the shadows, even if this means increasing ISO. Can't go with what worked for other cameras.What I've uploaded is straight from RAW to jpg - no adjustments.
I would appreciate if someone with GH4 would try to recreate the same thing. Thanks!
To help me!No disrespect, but why would anyone want to try to recreate that? Avoid, Yes!
how about posting some shots you took with decent exposure? Not many cameras out there that can shoot what looks like 3 stops underexposed and lifted such as the shot you posted. And it's not just Canon Yslee. It's Red, sony, panny, nikon, iPhone, oatmeal box.To help me!To find out if all GH4's have that or only my unit has some defect.
Of course it was underexposed, shot in low light and higher ISO. What I wanted to now is if in same circumstances all GH4's render low light noise with horizontal lines or not.Looks like you shot in very low light at a high ISO and then pushed the image too far in post trying to bring the exposure up.
I seriously doubt your camera has a defect.
