MrFluffy
After a long and protracted problem regarding noise with my HMC-151 and the terrible service that Panasonic provided I discovered that one of the default settings in the HMC can cause you to get very noisy looking images.
The original thread is here:
http://www.dvxuser.com/V6/showthread.php?t=159062
By default, when you turn on the zerbras to get your exposure correct, you will under expose your images. The default setting for the zerbras is 80% which is too low and cause underexposer.
Go ito the menu and set this to 95% and you will get crisp clean images.
I hope this helps someone avoid the problems I had.
:beer:
:beer:
