I see a lot of footage make with FS7 and yes there is a aliasing hightlights "issue" like FS700.
This morning I have spoken with prime support Europe and they have told me that this is a caracterist of signal process and the name of this is "tearing".
This can't be solved with firmware update.
It's a really pity, I understand it...
I believe this is the video Suguru is referring. I watched it again at full res and I'm not sure if it's aliasing / tearing (it could be) because the lens they used is terrible. There's pink Chromatic Abberations on many of the highlights, so that makes it hard to determine if it's aliasing or CA from the lens.
Suguru, are you referring to the guy's arms when they are at the table in front of the white sink? Aliasing might be there, but I'm not an expert and the lens is causing lots of issues. If there is aliasing, it's definitely a lot less than the FS700.
