I thought it would be worth sharing that the sensor/compression is still exhibiting signs of weird blockiness and aliasing in areas of high contrast (mostly with diagonal lines) on 4K XAVC-I
100% Crop video
The metal piece is sort of a "K" shape, if you look at the underside of the top diagonal, you'll see the artifacts.
This was also on the FS700, but was virtually eliminated when using RAW out and recording ProRes on the Odyssey7Q. I assume we'll get similar (clean) results when using the Extension Unit.
100% Crop video
