Not entirely sure where to post this question so maybe someone can answer here or make a suggestion...
I'm starting to explore Sony's HFR capabilities (specifically with RX10ii and RX100iv that I just acquired. I'm a bit confused about the 180 degree shutter rule application when shooting in HFR modes. If I want to, for example, shoot at 240fps/24p... should I be looking at 1/500 shutter (using the Manual mode to set exposure parameters)? Same for the other frame rates... 480fps/24p would then demand the 1/1000 at that point, and then 960/24p would then demand 1/2000, which could obviously be very limiting... what am I missing?
I guess the confusion is because Sony is doing the conversion in camera to adapt HFR footage to 24p (for that cinematic look, that is) and I'm just drawing a blank here.
Any other suggestions or resources on shooting in HFR that you may share would be appreciated! Thanks in advance!
