lt-cartman
Hi all
I have a canon HF-S10
I Just had a quick question about TV / AV settings.
I usually use TV setting of 1/50 of a second and let the AV change as needed i.e. setting 1/50 second shutter speed and then letting the AV change from f1.8 to f8 as needed (or am I assuming wrong in thinking that the F stop changes automatically when in TV mode)
I want to see if i can do the following. keep the shutter at 1/50 of a second and say set the f stop to 5.6 or similar (for a greater depth of field)
So will this work if I do the following?.
Go into TV mode and set it to 1/50 sec then go to AV mode and select F5.6. Will this work? i.e. will the Shutter remain at 1/50 sec and the F stop remain at 5.6.
Thanks in advance
Toolman
Thanks in advance
Toolman
