Geno
I am hot on the trail of solving this frame rate mystery, and hopefully complete this beautiful editing suite. I have HVX footage in my project. I open up a 720/24p sequence, drop it into FCP and viola, no rendering. I open up the item properties and I see a frame rate of 23.98 (24p) Good so far but the "compressor" says DVCPro60p. I need to figure out how to get this footage to a projector, which has an HDMI input. Blackmagics HD Cards would seem to be a good fit (the Intensity Card has HDMI I/O for $250) or the more costly HD Decklink for $999, but the tech support tells me that they only support 24p over 60p from the Varicam. What is the difference between HVX and Varicam footage. Something tells me that this footage should be the same thing. If the card won't work with HVX stuff, then maybe I should shoot in 60p (supported by both cards) and then use a frame rate converter or Cinema Tools to conform back to 24p when it's all done. Are there any drawbacks to this method? Can a true 24p filmic look be obtained from 60p to 24p conversion, or should I stay 24p native for maximum resolution?
