Grisnjam
So I am a new GH2 owner and I recently got a Fader ND mark II variable ND filter and I would like some advise on how to use it.
I took a quick 1.5 hours at lunch the other day to test it out at a local park where I play disc golf near daily. I used the 14-140 kit lens (I have the 20mm but the step-up ring had not come yet to use the ND filter with it). Below please find the little toy video I made with the footage (only a few shots are the end are 20mm, the rest are 14-140; with ND when wide and without when telephoto-ed in):
I used the Manfrotto 561BHDV-1 on most of the shots, but I used it like a tripod. I would frame up the shot then use the bubble level to get the monopod exactly vertical and then start recording and take my hands off. This worked surprisingly well as the monopod was able to stand on its own on uneven ground. I only used software stabilization on the opening water shot and ending moon shot).
For the non telephoto shots I used the Fader ND in the following way:
I shot in 24p mode with shutter priority at 1/50 with the ISO set to 100. I had hoped that in that mode I would be able to see what the camera was setting the aperture to but I could not figure out a way to do that. So in order to push the F stop as low as I could I would start with the fader ND on minimum and then slowly twist it towards max watching the histogram, stopping once it started to shift left. I figured this would put me at the lowest F stop.
I am not quite comfortable going full manual mode yet but I guess that is really the way to go... Is my technique giving acceptable results?
Any tips on ND filter use with the GH2 (14-140 or 20mm) when outdoor in full sun?
Thanks for your time!
