Well that's good news. But the overall situation is still disturbing.I tested my card by filming with my HVX now and I can playback fine, it doesn´t seem to be the camera.
They were certainly inserted in an Apple while not write-protected, which is one of the no-no's for using P2 as far as I'm concerned. Still, I doubt that that could or would cause corruption. I mean, okay -- are you saying that the ONLY cards this happened on, was that one card with the odd files? Maybe it could cause corruption... but I sincerely doubt it.I did not format the rented cards before I filmed. There was some data on one card that seemed odd: small files that are not usually there on top level, next to the content folder. I will never use a rented card again without formatting it in my own camera.
Okay, this is just bizarre. Is that third copy to the same drive or a different drive? Is it perhaps that the corrupted copy is on, say, a firewire drive, where the good copy is on a USB drive, or esata or something like that?Also a third copy of one card which I made later (before I returned the card) is fine, although the first 2 copies of the same card are both corrupted (I see the icons. but can´t play the clips in P2 viewer- a red cross is in the top right corner of the icon).
There is no automatic repair that I know of. In the old days of DV editing we used to get hit with glitches like that whenever there was a dropout on the tape, and I used to repair them by going in manually and finding the glitch and then copying a block from the prior (or next) frame to cover up that glitch. If your footage is severely corrupted that might be a truly painful process. I don't know if anyone's come up with an automatic fix for that or not on P2 footage; it's just really not something that happens - ever - so I doubt anyone's invested the time to make a tool to fix it. But if they ever created a dropout-fix program for DV, that same technology should work on your P2 footage, provided they made it frame-size-agnostic.Or has anybody found out how to repair that in editing?
