Hey guys,
Have an urgent 7D tech question. On set today, we've been shooting footage and transferring to a MacBook pro in final cut to preview the footage and make sure everything is okay, but somehow the footage is becoming about a stop darker in final cut pro!
Here's what we're doing: when we open an unconverted file directly in QuickTime it appears normal, the same as how it's shot. But then when we open final cut, we go to log and transfer, load the card, select a clip, click add to queue and it starts to convert to ProRes. Once it converts, the footage immediately looks darker. When we try exporting the clip to a QuickTime movie, the footage is still darker than the original when loaded directly in QuickTime player, outside of final cut.
We did a test for the hell of it and loaded the original h.264 footage in final cut without doing the log and transfer conversion, and then exported that footage. When we loaded that footage in QuickTime directly, it looked normal. I should mention that the footage still looks dark in final cut but it doesn't seem to affect the exported clip. So it appears that something is happening to the footage when it converts to ProRes that is messing with the exposure.
We've tried it both with Final Cut 7 and 6.0.6, using both the Canon final cut plugin that does Prores 444 and outside of final cut as well, using just a compressor droplet that converts to Prores 422. Anyone know what's happening? Any help is greatly appreciated!
Thanks!
Trevor
Thanks!
Trevor
