But, I'm importing all stuff from A1, which is the best way to avoid dropouts (but not the best for cam's heads).
That's true for dropouts which has recorded to tape, but also playback could produce dropouts. Although it's possible to try re-capture those parts again. But you're right that it doesn't matter what cam is used for capturing. What I really meant was that I haven't mix tapes with other camcorders with my capturing device (A1). Same tape brand etc..Dropouts are inherent on the tape track and it will be there whether you use the A1 or another camera to capture.
the 85HD for Catholic weddings and longer plays etc... Why risk it? A $10 tape or a bad referral?
Are HDV mini dv tapes just the same as regular tapes?
If so is it worth paying that extra amount for a larger HDV tape case and sparkly "HD" wasjigs?
Just a thing i heard.
Prove me wrong!
I personally do not notice any reliability difference between VERY expensive digital master tapes and cheapo Maxell tapes from the leading department stores... i seem to get the same number of dropouts with both... which is about one per every five tapes.
But if you are really concerned about dropouts and and other such problems, get yourself a firestore drive... problem solved!
I was told that the Master quality miniDV tapes (about $10 each) are identical to the HDV tapes (about $20 each).
