jeffry alan said:The method I am suggesting is a modern day "Technicolor", in that there are three IDENTICAL prints. One negative (RAW), three+ print exposures combined.
J*
Because you are still limited to a normal dynamic range (6-9 stops). The definition of (H)igh (D)ynamic (R)ange is that it expands that range significantly (12+ stops), and a simple curves editor would have to be expanded as well to reflect all of the increased tonal range.
My first summary point.jeffry alan said:So to summarize:
-Whatever dynamic range you get out of any sensor is what you are stuck with.
-A simple curves editor is sufficient to reveal details throughout the dynamic range inherent in the RAW file.
-Multiple exposures using different shutter speeds is the only reliable method to increase the dynamic range when combined.
jeffry alan said:From my research online it looks like you can acheive an enormous dynamic range with multiple exposure HDR, but then you have to tone map it to monitors and such that have a limited dynamic range.
I guess that begs the need for supporting hardware to be engineered to ensure a continous workflow that maintains the quality of the images from aquisition to exhibition.
I hope that the Mysterium sensor at least will offer an extended dynamic range compared to the sensors out there today. And combined with an advanced image editor that can really tweak the shadow and highlight details, the output should convince companies to support the revolution.
J*
Tu habla ingles?im.thatoneguy said:Hehe funny idea just crossed my mind. It's based on a high end photoprinter with the 8 color inks (dark and light versions of CMYK).
For the sake of easy math. Let's say a 4k bayer sensor is actually a 2k RGB sensor. Now if we could get an 16k sensor we could have a 6 color bayer pattern which by my probably completely wrong math would work out to a 4k RGB sensor. Just call it a Super Bayer. with say a 1/8 ND you could theoretically get a pretty significant dynamic range increase.
Optimally these wouldn't be square pixels, each sensor well would be two rectangular sub-pixels.
Now characterizing a chip like that might be a nightmare.
jeffry alan said:Tu habla ingles?
J*
Sorry for the jump, I was thinking about the sensors.Graeme_Nattress said:Jeffry, that's a different question all together. Foveon is a very interesting technology, but it's not without it's own flaws, the major one being it doesn't run at 60fps at a decent resolution, making it unsuitable for high definition motion picture use.
Graeme
