Recording in ProRes 422 10 bit trough HDMI only
2.5 SSD or Harddrive hot swap
LANC Display and hot swap LiOn SONY
Good new toy shipping december
http://atomos.com/
Supported Input Formats HD
1080i59.94
1080i50
1080p24
1080p23.98
720p59.94
720p50
SD 480i 576i
NINJA SPECS
Dimensions (without Batteries) 112(W)x83(H)x40(D)mm
Power Operating Power : approx 6.8W (screen on)
Operating Power : approx 6.3W (screen off)
Batteries
2x Small Battery Packs 31.7 Wh 4.5 hrs recording
2x Medium Battery Packs 63.4 Wh 9 hrs recording
2x Large Battery Packs 126.7 Wh 18 hrs recording
Automatic and manual switchover of battery for continuous operation
Colour 16:9 TFT Touch Screen
Size 4.3” diagonal
Resolution 480x270
Aspect Ratio 16:9 Native / 4:3 Letterbox
Video Input HDMI Uncompressed
Supported Input Formats HD 1080i59.94, 1080i50, 1080p24, 1080p23.98, 720p59.94, 720p50, SD 480i, 576i
Recording Time
HDD SSD
300GB 500GB 750GB 128GB 256GB
all video input formats supported
ProResHQ 3hrs 5hrs 7.5hrs 77min 2.5hrs
ProRes422 4.5hrs 7.5hrs 11.5hrs 2hrs 4hrs
ProResLT 6.5hrs 11hrs 16.5hrs 3hrs 4.5hrs
Audio Input HDMI 2 Channel or 6 Channel Embedded
Line In 2 Channel Line Level Audio. Analog gain adjustment
Audio Output 2 Channel 0.5W Balanced Headphone or Line level output.
LANC LANC In and Out for integration with Camera LANC and Accessories
LANC Controller feature
LANC Loop feature
MASTER CADDY SPECS
Dimensions 74x101x12mm
Supported Storage 2.5” SSD or HDD minimum 5400rpm
Standard 9.5mm height or slimmer drive supported
Master Caddy Dock 2.5” SATA to Firewire 800, USB2/3 and e-SATA
Supported Computers (for SATA adapter) Mac - All MacBook, MacPro, iMac and MacPro Models
Windows All USB2/3 or e Sata compatible Notebooks, and Desktops.
Note: Apple ProRes Quicktime Application required to run ProRes on Windows
Applications Final Cut Studio – All Apple ProRes supported versions
Quicktime Mac and Windows
Accessories Universal Battery Charger 110-240V
Tripod Screw mounts and adaptors
Protective cases and Travel Bags
http://atomos.com/
1080i59.94
1080i50
1080p24
1080p23.98
720p59.94
720p50
SD 480i 576i
NINJA SPECS
Batteries
Size 4.3” diagonal
Resolution 480x270
Recording Time
HDD SSD
LANC Loop feature
MASTER CADDY SPECS
