Sorry I kind of wrote this post while still trying things,
basically what I'm looking for now is a good batch converting program that I can load all my .mov files from t2i into and convert to Matrox or Ut Video codecs in .avi format. Prism and MPEG Streamclip have issues for me.
Also a quick question about cineform VS. these free codecs;
Cineform claimes to "Properly Interpolate" the 4:2:0 chroma to 4:2:2
What's confusing me here is that, DNxHD, Matrox, and Ut Video all render to 10bit 4:2:2. Isn't that giving the same effect that cineform codec gives? Or does cineform do some special stuff hence the "Properly" line in their quote.
v Stuff I wrote here while testing, you can read if you want v
Just spent all of yesterday trying to find a good codec and program to batch convert my footage too, I've been using the normal .movs but they've been really sluggish in my editing program and I heard that they're worse in color grading...
Anyway I found a few methods:
MPEG Streamclip+DNxHD > Convert .mov file to DNxHD .mov
For some reason when I do this, when I bring the DNxHD file into my editing program (Sony Vegas) It's a lighter color, as if it lost contrast or saturation, it's the same when I play them in MPCHC, although when I open them both in quicktime it's the opposite effect.... [weird]
So then I found this other method
Prism Video Converter+Matrox / Ut Video > I convert the .mov to an 4:2:2 Matrox .avi, or an 4:2:2 / 4:2:0 Ut .avi
The only issue I'm having with the above two methods is that the file it produces comes out darker, or more contrasted compared to my original footage.
I'm pretty sure my problem above is from Prism Video Converter, I just tried rendering Ut Video & Matrox out of Sony Vegas with the original .mov and no color changes at all
When Neo Scene detects 4:2:0 chroma it properly interpolates the source chroma to 4:2:2 for more accurate color processing during editing and effects work. And if you ever "key" your material, CineForm’s chroma interpolation will substantially improve your resulting visual fidelity.
