C100: Hang on to your EF Lenses...
bengiles
This just dropped into my inbox:
http://www.blackmagicdesign.com/products/blackmagicursa
Blurb:
Over the last few years it’s been really amazing to watch some of the work being done on our cinema camera and some of the rigs that have been built around it. But when we designed it we never really thought it would be used on such large jobs. It was really designed to be a small intimate camera used for creative work where you need to get in close and personal.
So we have been watching these larger rigs and thinking about how people are working when they do large shoots. Our thinking is that we needed to design a professional full sized camera that had all the extra on set equipment built into it, so there was no need to rig it up as much. We also wanted a camera with enough size to fit a very powerful cooling system so we could run high frame rates without fan noise.
The result is URSA, our new camera for professional shoots. It features a stealthy machined aluminum design that’s incredibly strong and has been designed for large film crews. We designed the camera to be divided into separate DOP, camera assistant and audio engineer workstation areas so multiple crew can work around it at the same time.
The DOP station features a massive 10 inch fold out on set monitor and separate 5 inch screen for settings, camera status and scopes. The camera assist station features a separate LCD screen for camera settings, status and scopes and the audio station features audio meters, controls and audio connections.
URSA also includes an upgradable Super 35 4K image sensor with global shutter, 12G-SDI connections, XLR audio inputs with phantom power and dual CFast based RAW and ProRes recorders. There is a total of 3 LCD’s built into this camera!
One of the reasons we have been able to put in such high quality displays and features is because the camera is user upgradable. What this means is the whole sensor and lens mount simply unbolts from the front using 4 bolts and then it can be removed and replaced. So in the future when new sensors are available you can upgrade simply by swapping the sensor and lens mount assembly. This makes the camera virtually future proof!
URSA is available initially in 3 models. One includes EF lens mount and one has a PL lens mount. An example of how you can upgrade the camera would be if you ordered the EF one, you could later purchase the PL lens mount and install it yourself.
One of the weirdest ideas we had was to make URSA available without a lens and sensor and the URSA HDMI features a ‘cheese plate” with threaded holes and a HDMI input where the sensor and lens mount would normally be. This means you can use any camera on the URSA body and get all the benefits of big screen, scopes, professional audio inputs, CFast recorders and more!
The camera runs at 60 fps, however the body has the high speed processing and high capacity cooling to run beyond 100 fps, so when faster sensors are available you could upgrade and then get higher frame rates.
There are a lot more features in the camera than I have space to describe here. The Blackmagic URSA EF will be available in July for $5,995 and the Blackmagic URSA PL will be available for $6,495 from July.
I know Blackmagic like to makes promises they can't keep, but this could be quite a challenge for Canon etc.
I had to check it wasn't 1st April...
the camera is so much more than 6,000 camera. I started looking into it and pondered about selling my c100 but, what got me the most was the sticker shock of the CFast 2.0 cards..holy shnikes! also its 16# shes a big girl.
Point taken about their ability to actually ship cameras on time......but now we got this new camera announcement.....What IF they actually deliver these on time???
I hope they do....can only set the bar for anything anyone else brings out.....
What IF the BMCC came out when expected, what IF the BM4K did? Etc etc etc.
Looks great, and props to them for trying to put pressure on the industry.
Anyone ever read the boy who cried wolf? lol
Big challenger for the Amira?? This shoots at 400 ISO with fixed pattern noise. The Amira, you can easily get away with 1200 ASA. No challenge, but maybe next year they will release this with another more sensitive, less noisy chip.
