Intra frame H.264 uncompresses just fine and is comparable to other codecs.Also, I'm not sure how the edit performance of the intra-frame H.264 would perform
I generate it with ffmpeg and x264.Cary—I'm curious, are you speaking from actual experience with the format or is this based on theoretical published specs. If you have experience with H.264 Intra, how are you generating that file?
That entirely depends on the encoding options you specify.Yes that's pretty much the nature of h264.
H.264-intra edits just fine.Yes, you deliver in a delivery format like h264. But this was about editing h264 wasn't it?
I'm curious now...what mfg's / camera's etc are using intra frame h.264 as their recording codecs?
