Hi All
Our camera is going back to JVC. Through our extensive testing we have discovered two pixels gone on the CCD. One black and one white.
We think this means one is always on and one is always off.
So someone else will have to provide info on there experience with the camera. If we have ours in New Zealand there must be lurkers out there from Australia which had a shipment of 300.
As Matt reported with FCP5 we could only bring in DV or 30p material, no luck with 25p nor did we have an opportunity to try 24p.
The camera does not down convert like the Sony so you need to shoot DV or HDV, you can't change your mind.
The test shoot I did in a local park was in 25p so we can't do anything with that. The 30p material is just workplace tests so not worth putting anything up.
Will let you know how we go with JVC on the dead pixel issue.
