Greenscreen, plates, and compositing oh my!
ronin99
Hello,
My greenscreen/compositing experience is limited to pretty much talking head interviews and I was kind of thrown into this after the fact.
So there's a couple of scenes in this short, that are rather advanced for me.
1. We want this monster to climb a wall and end up on a vaulted ceiling like this
The shot is static so we shot a plate of the empty ceiling and took some measurements, but what do I do on the greenscreen set? How do I have actor move, and camera positioned/angled to make this come together in the composite.
2. There's a part where a person with a flashlight comes across the monster and the monster moves toward them. So the light from the flashlight illuminates the monster.
We shot a few plates, as we were not sure which would be best, we shot one with flashlights on the background and one without.
So we have a few options on the greenscreen and I'm not sure what will be best for the composite. Just to be clear we don't see the actual flashlights in the composite, just the light from them.
1. shoot the actor with flashlights, and composite him into the plate without flashlights.
2. shoot the actor without flashlights, and composite him into the plate with flashlights.
3. shoot the actor and flashlights separately.
4. cgi the flashlights?
Any help is greatly appreciated.
With static plates, I've had good results with a large HDMI monitor (really a 22" TV). Cover it with clear static cling material or clear acetate & playback the BG plate on it. Using a sharpie, outline the walls, props, and add some perspective lines.
On your green set, use the same focal length/lens, tripod distance, etc and verify your alignment using the sharpie art.
Will your wall/ceiling green screen set be at an angle that's easy for the talent to climb? (IE, as if you tilted the room on its side?) You can either move the camera to match, or rotate the line art on the screen to check angles.
Proper shadow density, softness, and angles will go a long way to gluing the shot together, so shoot a lot of reference on the "real" set and make notes of the lighting used.
Also, shoot some handheld reference - just a mark on a wall. After the shot's assembled, track the reference and add it to the comp - it can really "sell" a static shot and make it seem like you used motion control (if handheld's appropriate for the shot).
And most definitely get Mark Christensen's AE book, which covers keying in great detail. Do some tests, and test your green lighting for the best exposure. You want one eyedropper hit to clear as much green as possible without tweaking the software.
I took a green screen to the paint store and had them color match it in flat latex - you don't need pricey chroma paint. Savage chroma green background paper is tough to key - not nearly as saturated as a screen or paint. It's really convenient for floors, but can cause profanity in post.
