Hadn't used the Canon 135 F2 in a while: 1DX II + 135 F2 @ F2 + Tiffen variable ND. G3 wireless (need to work on mic placement/wire hold (tape or clip) to reduce rustle), Audition Spectral edit to remove screaming kid (at the beginning where Jacqui's voice briefly sounds funny). You go into Sprectral View, then paint the 'scream harmonics' (easy to see), then press delete and does a decent job of reducing. Can repeat delete and completely remove noise, but then talent voice is too affected. Did a slight FFT eq to make edit less obvious. Also applied PP CC's new DeNoise filter (with Light preset). A Highpas filter at 200Hz was used to reduce most of the mic rustle, along with an FFT filter to fine tune: all done pretty quickly- less than a few minutes total.
No color work in post other than contrast and slight saturation + WB (Filmic Skin picture style).
While the Canon 135 F2 is a sharp lens, it looks kinda creamy at F2 through the Tiffen VND- didn't think diffusion was needed in post after viewing on YouTube in 4K (+ used 25 sharpen in Lumetri; in camera sharpen is off).
EDIT: + post diffusion - which is preferred?
