AC90: Good Wide Angle Lens?????
mikeroi
I purchased my AC90 about 4 months ago, and I'm still getting use to it.
I wanted a wider picture, so I purchased a $40 0.45x conversion lens from eBay. It does in fact widen the frame, but NOT as much as I'd like...
Im going to be making some virtual tours for a real estate company, and need to be able to show lots of space. So I'm looking for a WIDER lens, Does anyone have any suggestions?!
Let me know. Thanks!
If you want wider than .45X you are going to need a fisheye lens. That is going to distort your image significantly. I'm sure there already is plenty of distortion with the .45X as-is.
There is this:
http://www.bhphotovideo.com/c/product/673938-REG/Opteka_OPT58EF_X_TREME_58mm_0_3X_HD.html
You would also need a 49-58mm set-up ring. It shows a 180 degree viewing angle which is about as wide as you are going to get. Just remember, you will get serious distortion and it will most likely be quite soft in the corners as well.
