New_Zealand
Shooting on the Canon C300 Mkii. I got a good light weight tripod but the head isn't that great. I need something that can handle good lens weight but won't kill the pocket book. The full setup is about 20lbs.
The size and design of the legs on the 75mm and 100mm Flowtech are almost identical, so the 100mm is not necessarily more stable as far as the actual legs go. Of course the top of the legs are a bit wider at 100mm which could give slightly more stability, but moreso, there aren't many heavy duty 75mm heads available so one is forced to go 100mm and pay almost 2.5x the price for the Flowtech 100mm. Really a ripoff in the sense of it couldn't have possibly cost them that much more to make the 100mm and they're charging what they do because they can. But still, they're great legs, so worth it.The head is very suitable but the weak point at 75mm bowls are mostly the light legs.
Not sure how much this translates to direct stability but apparently the Flowtech 100’s do have some other differences when compared to the 75’s. But I imagine you probably wouldn’t see much difference with a C300 since most of the improvements are to hold more payload.
“The leg-clamping mechanism has been improved significantly so that each leg holds in excess of 30kg. The quick-release levers at the top of each leg are completely new and larger with new internal cast parts to make them stronger. All of the castings at the top of the legs upwards are completely new and larger so they are stronger to cater for the higher payloads and bigger heads, several moldings are also completely new and it has the same height. In total, approximately 30% of the main components have been redesigned and are new on the Flowtech 100.“
klk;1986826424 If on a very low budget and buying new: 1- E-Image heads. personally I like the feel on these budget heads. [url said:https://www.bhphotovideo.com/c/product/1046960-REG/e_image_eg10c2l_e_image_gc102_2_stage_carbon.html[/url] Have no idea how they will hold up, and I would get a "heavier" E-Image head compared to weight ratings. I went to B&H and tried all the cheap heads on display (there are many) a few years ago and came a way thinking the E-Image heads felt the best to me- for real budget fluid heads. I believe the company is based out of South Korea. Also don't know how stiff the tripods are. I have the GH03 that I've used with DSLRs and it feels smooth. Doesn't hold a lot of weight, so they are rated on the light side- also the tilt lock is weak. But it's smooth for the money.
