Ok, many thanks!I would and have gone full internal with the least bit external (0.3 - 0.9). Lowers the chance of a heavy external ND introducing a color shift, IR or far red. The internal sony filters on at least the F3 and 5/55 do not seem to create any changes beyond pure ND. I'd imagine the FS7 is the same.
I can't find and info on it but it must, I shoot outside often and do not get the red /magenta shift with the FS7 internal like I did with the FS100 without IR externals.... I will test but I think some IR filters will give you a green cast when combined with the internal. (pretty sure it was a Tiffin)If using that much ND, should you use an external filter that includes infra-red reduction? Or does the FS7 have have IR control built in?
