George Loch
What are your go to lenses on the C200 for interviews and general b-roll?
-gl
-gl
-gl
Canon 17-55 f/2.8 for when I want a fairly shallow depth of field.
Something to keep in mind with this lens is that when shooting raw (17x9) this lens often vignettes in the corners of the frame when you're on the wider end of the lens - and if you have image stabilization on it becomes even more noticeable. This is because in raw it uses more of the sensor (closer to a 1.5 crop instead of 1.6) The amount it vignettes seems to vary from copy to copy of the lens. Mine was so bad even in 16x9 UHD that I had to get rid of it (used to be my favorite lens), however my friend has the lens and never shoots raw on his C200 and has no vignetting problems at all.
For those interested we covered this topic pretty in depth in this thread: http://www.dvxuser.com/V6/showthrea...r-C200&p=1986742676&viewfull=1#post1986742676
-gl
I have to say I bought the EF 24-105mm f/4.0 IS II, thinking it would be the FF replacement for the 17-55 to get rid of the vignetting in the corners, but I really dislike the 24-105 for some reason.
