Simple:"Easy" is certainly relative. I don't have a lens tech / collimator in my area. And I'm not sure I want to DIY the back focus on a still lens that I also use for autofocus stills and certainly didn't expect to be cinema style parfocal when I bought it.
But I'm all ears if it's super easy...
1. check the back focus and determine the error.
2. Shim accordingly.
The fact you can't won't do it means just that. For a competent person with right equipment it is easy.
BFD has nothing to do with parfocality.
The former is a design property. The latter an adjustment that needs to be performed periodically as a part of the equipment maintenance.
Who told you that you don't need to maintain your gear any more?
I used to tweak focus on brand new UPs, MPs, Cookes, Angies that cost 10-100 times as much and nobody complained....
Optics for motion capture need to be maintained properly or they will quickly show their faults unlike still capture.
Blaming the manufacturer will not change it- they don't know the exact flange depth of your personal camera so to match the back focus to that...
Which is not to say they should. The proper way to do that is to set your camera flange depth to the standard , then set your lenses BFD to the same standard and voila- everything is now sharp and beautiful....;-)
