Glass for EVA-1
What else is out there that you use and like for low CG for handheld? ;-)
I build my own, which isn't that complicated and is a lot less expensive. I generally forgo the use of rails and a matte box, because anything under the camera raises it's CG. Since I used an Aaton for nearly 30 years I tend to try for that form factor. I mount an EVF, in my case a Gratical (so I have nothing against Zacuto) mounted off the handle. As a matter of fact SHAPE has an aftermarket handle that should work well, although I haven't actually seen it on a camera. I usually build a plate from 2" aluminum channel, available at any hardware store, that I cut so the channel portion is only on the front of the camera. That's where I put an Arri rosette (SmallRig). I've been using a MovCam extension and handle with LANC button on my LS300, but on the EVA I'd obviously use it's grip, that is if I can figure a way to mount it to the extension. I don't like the grip to be too far outboard because it throws off the balance. I used a Zacuto grip extension on my C100, but that required rails, so I rebuilt it to mount on a rosette so it's more centered like the Aaton. I'd do the same for the EVA if I decide to plunk down the cash for one.
Right now I'm not totally unhappy with my LS300, even though it's 8 bit (at least they did upgrade the firmware recently so the UHD is 422), so I'm going to let the dust settle on this release until I'm sure it's what I want.
You're kidding right? I shot handheld for over 30 years, with much heavier cameras, before anyone even heard of IS. It is possible, even with a long zoom, if you develop a good, personally designed, well balanced, low CG shoulder rig (not a Zacuto Recoil!) - and practice, like you would for a sport. Watch the remastered 1967 MONTEREY POP if you don't believe me.
I know I'm in the minority in this millennium, but I'd prefer a manual zoom, built with modern technology to keep it lighter, but without the bells and whistles. The new Fujinons seem to be just that - sadly they can't be adapter to EF.
Weight is beneficial to steady handheld work. The more heavy the camera the more steady the shots, generally speaking. Many who are of the "5D generation" are rightfully concerned about lack of IS because with lightweight cameras like the 5D and now the EVA / Fs5 / C200 the handheld work can end up jittery as a result of not enough camera weight to smooth things out.
Back when pro camera rigs were all 20+ lbs the handheld work didn't need IS as a result of the weight of the cameras making the shots more stable.
Someone mentioned using Nikon glass with a reversible follow focus- but using a follow focus slows things down when you are speed-shooting / running & gunning. It is an extra step that requires a bit of extra time for performing lens swaps. That can add up and slow you down when changing lenses 20-30 times per hour, when a straight lens swap without follow focus resetting is already causing you to miss shots. The fact that Nikon stubbornly sticks to that focus direction and loses untold profit in sales as a result is maddening. WHY?!?!?
I'm the FF guy. I really change lenses maybe 2/3 times a day mostly I'm on a 55mm on a speedbooster then sometimes 35mm and a little 85mm once a week a 300mm
Of course shoulder-mount cameras were just that -- you put them on your shoulder - which tends to be much more stable than extending your arms in front of you - as in the case of using the screen on the back of a dslr. I found that my A7s footage became twice as stable when I used the little viewfinder and kept the camera pressed against my face.
And of course Nikon continues to use their focus direction because they're not Apple - so they care about compatibility with the millions of existing users/ camera bodies out there. Of course I started out with a Nikon F.. and couldn't believe that Canon focused in the opposite direction when their lenses started to be good enough to compete. I just still can't believe that Nikon has gone over to 'G' system and eliminated the iris ring. I guess that's why I still use the old 28-70 / 80-200.
Interesting historical note, that has absolutely NOTHING to do with this thread. Nikon offered the S series cameras in the 50s (an excellent little camera, I had two S-2s in the late 60s).
Those cameras had a little wheel on top next to the shutter button to adjust focus. The wheel turned a gear that turned the focus ring on the lens. A great innovation designed to compete with Leica's M cameras. (Japanese products were considered junk then).
The wheel turned in the "correct" direction, clockwise (when looking from the back) for close, counter-clockwise for infinity. But because of the gear, the lens rotated in the opposite direction. When they did away with the focus wheel, on the F cameras, they never changed the lens' focusing direction.
Would reversing the focus direction on their lenses make those lenses incompatible with existing Nikon camera bodies? I don't see why it would. As far as AF it is simply a matter of electronics, is it not?
I just think Nikon loses a lot of sales as a result of their manual focus direction being the opposite of nearly everyone else. Think about how often you see someone using Canon glass on a video camera and how rarely you encounter anyone using Nikon glass on a video camera. It has to be at least a 50:1 ratio, advantage Canon.
I didn't intend to hijack this thread, so, getting back to lens choices for the EVA- has anyone mentioned the Canon 18-80mm?
Manual Nikon glass has always been popular with cinematographers way before SpeedBoosters were created, which is when you really started seeing many more Canon lenses on other cameras. As we know, the Nikons were the only affordable lenses with manual aperture rings.
I'll go out on a limb and say 'everyone' on this forum was shooting on some type of fixed lens prosumer camera around 2008-2009 and then eventually made the jump to the 5D Mark II, which led to most people building a collection of EF glass over the next years. So when the SBs came out, the logical step was to use those lenses with adapters rather than starting over.
Also, these days - I think the younger generations are learning how to focus both ways (if they aren't letting the machine do the job for them). Personally, from using so many different cameras (and therefore lenses), I can focus both ways if I use my brain.
I often used early Nikon F lenses on my Eclair NPR, in fact I still have the 24, 35, 50 and 105. Jumping between those lenses and an Angenieux 12-120 always caused a problem when working fast though. True, you can adapt your brain (similar to driving a car in the UK or Jamaica) but, for me at least, it isn't easy. There is/was a FF that allows you to reverse the gear when you switch. I don't remember the model, or know if it even still exists, but that's a solution for mixing Canon and Nikon.
It's not Canon vs Nikon. It's "pretty much everyone else" vs Nikon. And yes there are certain manufacturers with follow focus units with reversible gears so your hand always rotates the same way regardless of what the lens wants to do. I remember painfully learning how to pull Nikon focus when using 35mm dof adapters on small chip cameras 2008-9, then with DSLRs 2010. Rough because I'd then routinely go back to my Canon lenses, and of course the Fujinon broadcast lenses, and sometimes PL-mount cine lenses which all rotated the same way. I developed a hatred for Nikon. When working fast I'd gladly sacrifice lush image quality for "getting the shot" in focus and on time. Nowadays, I don't bother with Nikon ever, and don't have to. EF is a legit cine lens mount and that helps. The PL mount mod from Wooden Camera helps, too, for EVA1.
Heart is still beating fast from the rush, but just ordered a Milvus lens kit from BH on Black Friday. Smoking deal for anyone interested - best deal I've seen anywhere including after bundling gear with shops on a discount. And, you get 4% back on many of the lenses 2 months after they ship.
Milvus 15, 21, 35 (new 1.4), 50, 85.
Milvus 25 1.4 wasn't on sale but I am looking to pick that one up too as it looks very nice... and debating returning the 21mm if it is too similar to the 25. Not sure if I really need both.
I will miss having any form of IBIS or Lens IS on the EVA1 / Milvus setup... I did work for years without any stabilization, but once you have it (ie Dual IS on GH5, or even just IBIS) it really is a taste of magic (not a crutch) and allows for very nice camera moves and flexible handheld or quasi-handheld work with no jitter. But the weight of many of these Milvus lenses alone is 2-3lbs + EVA-1 so hopefully that will help stabilize things with a steady hand (Looking at the Zacuto Recoil Rig, but I don't always love working just shoulder mounted, as I find a lot of flexibility in shooting at hip/chest level, or introducing camera movements when held out from my body).
the sigma 18-35 is on sale through rest of today for $100 off + 4% rewards (or 5% rewards on amazon prime card) on both BH/amazon. I'm debating this as well as it might pair really well for a zoom option on EVA1 and GH5 + speedbooster.
But I already have the Milvus lens set, a speedbooster, and a bunch of m43 native glass. It's not really necessary... but if it's a handy enough "must have" lens, an f/1.2 speedboosted zoom on GH5 + a zoom option on EVA1 might come in handy...
Any input as to if this is actually a worthwhile purchase (and a good enough deal to consider NOW) given the glass I already own? Must-have in general, or a must-have only as a cheap all-arounder?
The only two lenses I currently own are the 18-35 and canon 70-200 (plus a set of nikkors collecting dust). The 18-35 is an amazing lens. What focal lengths are in your Milvus set? If you're already covered I wouldn't bother.
15, 21, 25, 35 (+ 50/85) - it would only be to add a zoom option for EVA1, and a lower light speedboosted zoom on GH5 (speedboosted to ~1.2, faster than the 12-35 lumix 2.8)
if the zoom option is important to have while rolling - my Sigma 18 -35 is far from parfocal. It is a great lens - but you'll need to move up to the cinema version if you want par focal zooms
I'd be surprised if anyone bought the cinema versions of the lens so they can zoom while rolling.
I find it hard to believe that a lens with less than 2x zoom is not parfocal. The BFD may be off but that's easy to fix.
Mine isn't parfocal either. I doubt there's much incentive for sigma to spend $ making sure their (stills) lenses are parfocal.
Most lenses that were claimed "not parfocal " I found had their back focus off. Mostly short since that's the safe direction for lens manufacturers. Are you sure the back focus of your lens is correct?
Have you had it checked on the collimator? That's a good start...
"Easy" is certainly relative. I don't have a lens tech / collimator in my area. And I'm not sure I want to DIY the back focus on a still lens that I also use for autofocus stills and certainly didn't expect to be cinema style parfocal when I bought it.
But I'm all ears if it's super easy...
