GH5 gh5/g9/g90 as a camcorder
Honestly, I don't know how I would feel about them...I don't zoom while filming, but if I had to then I don't think I would use either. At this time, I don't imagine them being better than a thick zoom rocker that has great pressure sensitivity and works well with my muscle memory (from many years ago).
you talking about a camcorder then... :)
Well, then maybe the Panasonic FZ2000 is an option. It is considered a bridge camera but handles a lot like a camcorder. It also has built in ND. The specs are quite similar to the AX700 but it is substantially cheaper. But if the recording formats of the AX700 are inadequate for you than I don't think you're going to get the entire package you are looking for unless you're stretching your budget further. JVC is typically a brand I overlook but which also has a plethora of options. However, I think they all hit a similar price point when comparing at a similar feature set.
well, recording format are not on top of priority. In top i have autofocus, zoom range (and ease to use) and sensor..not less than 1''. Also a small format..not bigger than ax700
I have considerered also the fz2000, but it seems that it has, as most of panasonc, not good AF. It can be a competitor to zv1, which i am considering also..but i think the sony should be better for many things...and it is newer technology...
at the moment options are zv1 or ax700...big differetn in price, but if i can find a good bargain on ax700 i might go for it. zv1 is always there, i would like to try one (i also would like to try the ax700 but it is more difficult...i can buy zv1 on amazon and retrun, ax700 is more difficult to do that, more money to pay, hard t find..)
E-10 has a zoom rocker on the body and is $800 w/ the 16-50 kit lens. Add a Tamron zoom for the "camcorder like" quality.
this is somehting i wanted to know..how easy is to zoom in out while shooting with the e10. What tamron zoom are you talking about? i still want to keep the whole kit in a easy portable way
The camera isn't released yet, so no one knows how it works with every zoom. Presumably, it should work with the most recent versions from all manufacturers.
Went over this already...
Sony's power zooms only.
The lever switch on the camera is not going to physically move the barrel of other zoom lenses.
It's about the design...all of the zoom lenses that Tamron or others make require a hand to twist the ring to zoom.
(Sometimes you have to actually use the gear to answer questions, DLD, lol.)
Only Sony makes a few power zooms (like Panasonic does for their cameras) that work by having the camera control the zoom mechanism, retractability.
They are usually cheap kit lenses, but there are some with a switch on the lens. [And of course there are the other servo rocker ones that are more expensive.]
I guess my system of buying and selling gear without ever actually taking possession of it has a glitch.
so e10 is not an option then
Well, there are some Sony lenses that will work with the E-10 zoom rocker. There are apparently no Tamron lenses that will do likewise. At this point.
Tamron is part owned by Sony, so that may change. Or not.
Then there are external solutions - i.e., a separately powered zoom - but I am not sure how one'd go about it. The camera body is small, so one'd need a cage and a separate battery too. Which may make it unwieldy for some users.
for me e10 has sense only if i can put a wide zoom, keeping the whole thing as portable as possible
