Thomas Smet
4096x2160 = 8.8MP (1.89:1)
4608x1706 = 7.8MP (2.7:1)
I think you meant to type 4608x1920.
I don't know how it works with the GH4, but I do know on certain types of sensors there can be problems with going full width on a sensor, especially if the edge photosites are used for another purpose and not actually sensitive to light. I don't know if this is the case with the GH4, but some manufactures have claimed a total resolution based on photosite that do not actually result in a full pixels worth of information. There is one famous example of this, from a camera "manufacturer" that claimed to be using a "5.7K" sensor back in 2006, this of course was a lie.
There are a number of sensor which move data/electrons through specific columns/or rows around the edge that are not used for another purpose. Other sensors set aside some photosites for black reference, and then can avoid the black balance/black shading procedures that some other cameras need in order to function.
Regardless of an 8.8MP count being the same, my guess is that the arrangement of those pixels into something other than currently exists is likely a non-trivial matter. I would also suspect that as 4608x1920 is not a SMPTE or DCI standard, it's unlikely that Panasonic would add it without a lot of requests. I think it's more likely you would see 4096x1714, but (if you get framelines) you can add the crop in post easily and have room to reframe.
I will suggest this to Panasonic, as I believe the supersampling of a 2.39 capture with 4608 width (or some fraction higher than 4096) may have value if they can work the math so there are no scaling artifacts. I'm pretty certain they would still want to send it to the card with a mild scale to 4096x1714 to maintain DCI and not give an NLE (or other commodity software) a fit from a non-standard raster/file resolution. It would lessen the "crop factor" and probably result in an image with more resolution. A good suggestion if it's technologically possible.
There's a lot of players that have to be involved when you deviate to far from "the norm." If you are a manufacturer and you want your image file to enjoy wide cross-tool/platform support, then following standards make life easier.
The GH4 should be able to do 4608 wide because it can capture stills that are 4608 wide. I think the 4608 is already the effective pixel area.
