I'm not a great camera guy because I usually forget one of the steps in this list. I know nothing has to be SOLID / FIXED in stone, but what is the general checklist when setting up EACH SHOT for video? Here's a list I think is in order, but looking for other's input for corrections or changes.
The way I see it, a proper order affects things down the line that need adjusted. But, that COULD vary depending on the needed look and lighting.
Project level:
Resolution
Frame Rate (may be adjusted per shot, per the need for slo-mo etc)
CHECKLIST PER SHOT:
Shutter Speed - 180 angle or twice frame rate (1st because it affects the "look" you may want, thus light down the pipe)
Aperture - also affects light, and look, depending on lens and need
ISO - based on light coming in from the above two, as well as target native range of the camera
Scene Profile - depends on need: neutral, cine, whatever
White Balance - AFTER all that so you get a proper balance seen by the sensor
Focus - last before recording, always very important
Where does ND filter fit? Before ISO maybe?
Again, I realise there is no EXACT proper order, but I'm making a little checklist card so I stop forgetting parts.
Feedback?
Project level:
Resolution
CHECKLIST PER SHOT:
Feedback?
