I shot some clips with my GH3 the other day. When I try to encode them using FFMPEG I have an issue where FFMPEG kicks back an error
The odd thing is this error only occurs when I shoot using Manual Movie Mode. If I shoot using video from one of the still picture settings on the dial the file encodes normally.
Doesn't matter if I encode DNxHD, ProRes etc it fails. Not sure why clearly the files are different when it comes to the encoding even though looking at the codec details they look the same:
Stream mapping:
Stream #0:0 -> #0:0 (h264 -> prores)
Stream #0:1 -> #0:1 (pcm_s16be -> pcm_s16le)
Could not write header for output file #0 (incorrect codec parameters ?): Operation not permitted
