dan.carter
Anyone tried to assign ETC to a Function Button?
Doesn't work even though the option is there and it assigns it correctly.
Again, I know how to use ETC, I know it doesn't work in 60p, it works fine on the GH3 but it doesn't work when assigned to a Function Button.
Obviously having the ability to double your FL with a button press (in this case I assigned it to fn1) is optimum way to do it.
I was psyched when I saw the option to assign ETC in the menu, but...
Now along with fixing that, how about assigning Audio Record levels to a Function Button?
I've been able to successfully assign ETC to the Fn1 (Wi-Fi) button. However, I made this setting before assigning any Cust.Set Mem settings. This may not be your issue, but if you assign a Fn button after saving a Cust.Set Mem, then switch to another Cust.Set Mem, the Fn button reverts to its previous setting. Seems that for every Cust.Set Mem, you must assign the Fn, then resave the Cust.Set Mem. I've found this applies to other settings that I assumed were global as well.
Good luck.
