Uwe Lansing
http://www.vimeo.com/25186953
It´s the first time that I have a go at timelapses. In most of the shots some kind of weird dots are showing up - light and dark ones. Partly on the very spot - at 1:10 + 1:46 they are pretty obvious. At first I thought that it would be some kind of water dots or smudge. I cleaned the lens but the dots are still appearing. In normal film- or photo mode at shorter shutter speeds I can´t notice anything like that. Is it perhaps due to the longer exposure times? Kind of reflections? Any expert around here?
GH2, 14-140
Fader ND in around 70% of the shots
Music: Circ
Update 06-18-2011: I have tried out several things up to now
- I cleaned the lens intensively
- I tried to clean the sensor without success
- several test shots with different apertures and shutter speeds
results:
- the dots are still there at f16, f22 and long exposures like 2 seconds - with and without Fader ND. But it seems that the fader is causing the light dots at unconvenient light situations (as Alex said)
- as Sasha + Klaus mentioned here: the more you open the aperture the more the dots are gone. At f11 they are barely visible
- same goes for the shutter speed: at 2 seconds they are more pronounced than at 0,5 sec.
It isn´t really satisfying. I think that I need professional help for the sensor cleaning. But shooting sunrise/sunset timelapses at f8 or f11 with a shorter shutter like 0,5 sec seems to work quite acceptable with a Fader ND. Its definitely not the last word and I still don´t know what´s really going there but a prof. sensor cleaning seems to be essential...
