I know the source of this isn't the most welcome one around here, but for what it's worth - the mts is available for download:
http://www.vimeo.com/15410936
So my ignorance as a Canon shooter, what do I use to view the footage? MPEG Streamclip doesn't recognize the format. VLC shows it with terrible interlacing. This clip is outside my workflow of .mov to ProRes -> FCP.
It plays in Premiere Pro CS5 but looks less than good. No go in FCP.
That's some shi*ty looking footage. Interlace artefacts all over.
... There is no moire, artefacts or aliasing of any kind as far I can see...
Please upload the original .MTS file somewhere. Andrew himself stated the footage is no eye-candy. I want to look at the raw files, for presence of B-frames and such.I uploaded the clip to youtube and it deinterlaced it. At least this footage will be shareable without showing interlaced artifacts. However, it is nothing more than 1920x540 footage. Even if you render it to 1920x1080 you are just interpreting in the extra 540 lines.
Isn’t this 1080i footage basically the same as the Canon DSLRs that line skip. The 1080i footage basically skips every other line and then your display or rendering program has to interpret it back in. For the Canon cameras they just do the interpreting in the camera.
I think this footage looks better than the Canon footage when deinterlaced properly. However, it will never come anywhere close to the 1080p @ 24 mbps footage. I can’t imagine I will ever use the 1080i mode on my GH2. I will use 1080p for all low light shots and the 720p @ 60 FPS mode for all action shots.
Full HD interlaced footage is still "1920x1080," however two 1920x540 fields taken at two points in time (the length of a shutter speed) are used to combine into each "full" frame.....
But yes, in this day and age releasing a camera with interlaced video acquisition format is if not borderline "criminal," then definitely retrograde.
