GH2 hack project update
Vitaliy Kiselev
Carbonite Member
Small update on our status.
1. We cleared all problems with old account. So, now we have required amount to start first phase.
2. Next up we'll be targeting TZ10 as first dumping target (just because it is close to GH1 and GH2 and cheaper :-) ).
3. First results concerning TZ10 and our next plans will be not available on this site (so, most probably, it is last update here) and will be all located on our new site.
So, stay tuned.
Vitaliy, I understand that you are not going to be posting information here. However, does that mean that no one should post information about the hack here?
I'm a big fan Vitaliy, but I don't really get what this means. Does this mean that you've successfully hacked the GH1 and that the firmware will be available shortly?
Your the bestest ever
x2
He is hacking (dumping the decrypted firmware) a very similar cheap camera that uses the same encryption/flash system. Depending on if he manages that, we will all know if the new gh1/2 hacks can be done soon/easily. (He still has to code the hack after this encryption wall is broken)
Vitally - have you ever heard of a hacker named Razoola?
He cracked the capcom CPS-2 encryption.
I know that's a "simple" motorola 68000 based system,
But he's a pretty smart guy.
I have a strong belief in your decryption approach and I think it's totally feasible.
Best wishes!
Does this mean you've acquired the necessary hardware? or is that beyond phase 1
So, stay tuned.
i think that Vitaliy is pretty much implying that if you want further info on development, do it through the dedicated site.
What's the status in the GH-2 ?
Not able to start yet because there is no firmware-update to download for it yet?
How can other developers help?
The 1080p 80% slow motion can be sped up by 20% and yield 1080p @ 30 FPS. It uses the 24 mb/sec as well. Try it you will like it.
No audio though, if that's a problem. Make's syncing separate system audio a more time consuming affair.
