Matt Gottshalk
Resident Preditor
footage or it didn't happen.
qft!
Yep, I use the Panasonic adapter. It seems to be a real gem on these VDSLRs. The 1080P on the 5D Mark II really helps sell it though based on these pics and the full frame sensor might be helping as well. Through various tests, I've found that the adapter can work all the way through 300mm, I would test further but I don't have anything beyond 300mm. The only drawback is that you would have to stop down to get rid of the image blur, which is normal.
Just for laughs...
is there more or less aliasing on the 5D with the anamorphic adapter?
how wide can you go before you get vignetting?
On the 5D it starts around 25mm to 28mm.
On a APS-C 1.6 crop sensor, it's starts around 18 to 20mm.
However, remember that an anamorphic is a .67x wide angle lens just in the horizontal axis. So a 28mm becomes a 18.76mm lens approximately in the horizontal axis...
However I do like a bit of vignetting.
well as I have to crop my 1.5x anamorphic image to get 2.39:1 there shouldn't be any vignetting. yeah I generally add a bit in post. I added a little in my cemetery test footage for the film. It's barely visible but just helps draw attention to centre of the frame and gives it an extra filmic quality.
I wouldn't want to be there when hunter goes to war, he'd start lobbing nukes in a firefight.
Can't wait to see your footage you get with that baby.......
