GH1 Service manual
NURBS
Hello There'
Maybe someone have a Service Manual for GH1 ???
Link: http://www.tradebit.com/filedetail.php/9347462-panasonic-lumix-dmc-gh1-series-service-manual-
It's very interesting theme for update and modding GH1: :Drogar-BigGrin(DBG)
- Troubleshoot
- Service Navigation
- Specifications
- Installation & Operation
- Location of Controls and Components
- Maintenance
- Service Mode
- Service Fixture & Tools
- Disassembly and Assembly Instructions
- Measurements and Adjustments
- Parts & Circuit Diagrams
Thank you
Regards
Hello guys'
Some pointer (maybe necessary for someone):
About Main P.C.B. (Ref. 1) / Audio P.C.B. (Ref. 3)
  1. This Service Manual does not contain the repair service information for "MAIN P.C.B."(Ref.1) and “AUDIO P.C.B.”(Ref.3), because it requires special facilities and equipment.
    a. Schematic diagram, Block diagram and P.C.B. layout of "MAIN P.C.B." / “AUDIO P.C.B.”.
    b. Parts list for individual parts of "MAIN P.C.B." / “AUDIO P.C.B.”.
  2. When a part replacement is required for repairing "MAIN P.C.B." and “AUDIO P.C.B.”, replace as an assembled P.C.B. parts and send it/them to Central Repair Center.
  3. The following category is recycle module part. Please send it/them to Central Repair Center.
    *MAIN P.C.B. (VEP56084A: DMC-GH1KPP/GC/GH/GK/GN/GT)
    *MAIN P.C.B. (VEP56084B: DMC-GH1KEB/EC/EG)
    *AUDIO P.C.B. (VEP54012A): Excluding replacement of Lithium Battery
Service Navigation (Initial settings)
When you replace the MAIN PCB, be sure to perform the initial settings after achieving the adjustment by ordering the following procedure in accordance with model suffix of the unit.
  • Preparation
    Insert the SD memory card which has a few photo data.
  • Step 1. The temporary cancellation of initial setting:
    Set the Drive mode lever to [ SINGLE ].
    While keep pressing [ DISPLAY ] and [ FILM MODE ] buttons simultaneously, turn the Power on.
  • Step 2. The cancellation of initial setting:
    Press the [PLAYBACK] button, then playback the picture.
    Press [ FILM MODE ] and “[ UP ] of Cursor buttons” simultaneously, then turn the Power off.
  • Step 3. Turn the Power on:
    Set the mode dial to [ P ], and then turn the Power on.
  • Step 4. Display the INITIAL SETTING:
    While keep pressing [ MENU/SET ] and “[ RIGHT ] of Cursor buttons” simultaneously, turn the Power off.
    When MAIN P.C.B. is replaced, all of the model suffix is displayed as follows.
    There are two kinds of “INITIAL SETTINGS” menu format.
Service Mode
Error Code Memory Function
  1. General description
    This unit is equipped with history of error code memory function, and can be memorized 16 error codes in sequence from the latest. When the error is occurred more than 16, the oldest error is overwritten in sequence.
    The error code is not memorized when the power supply is shut down forcibly.
    (i.e., when the unit is powered on by the battery, the battery is pulled out)
    The error code is memorized to FLASH ROM when the unit has just before powered off.
  2. How to display
    The error code can be displayed by ordering the following procedure:
    • Preparation
      Attach the Battery or Battery Charger/AC Adaptor which is connected the DC Cable, and insert the SD memory card.
    • 1. The temporary cancellation of initial setting:
    • 2. The display of error code:
      Press [ FILM MODE ], [ MENU/SET ] and “[ LEFT ] of Cursor buttons” simultaneously with the step 1 condition.
      The display is changed as shown below when the above buttons is pressed simultaneously.
      Normal display → Error code display → Operation history display → Normal display → .....
Regards
NURBS
it is also interesting how you can set region of the camera but it can only be done once. Leaves room for someone thats a bit of a hacker to unlock regions me thinks.
Typical repair facility stuff. They have different "levels" of repair manuals to keep proprietary information centralized.
What we need is that main PCB document more than anything else.
I'm trying to figure out what the IC is that drives the HDMI output on the mainboard. The pictures of the board show an IC with 4712 written on it but I can't find any HDMI or DVI driver/controllers with that number. Matsushita(panasonic's parent company) doesn't list most of their ICs so I haven't been able to find anything in their brands either.
Svart, the file is no longer available. I did a search and they want $13 for the download. Do you have it available and could share?
I only have service manual 1. It does not include the schematics or BOM for the mainboard or sensor, both of which I am looking for and should be included in service manual 2/3.
Does anyone have a link for a service manual? I need to disassemble my new GH1 to modify it's lens mount. I'd feel much more comfortable cracking it open with a manual :)
