GH1 firmware research volunteers required
Is there a summary on progress? What's the status and benefit so far?
24P MJPEG?
No Pulldown required?
Thread's so long... hard to find info...
24p Mjpeg.....Works, but skips every 5th frame.
No pulldown required.....Yep, none required, but can't payback videos in camera.
AFAIK, the flash issue is with lenses which don't support automatic mode - so any lense you attach with an adapter.
the problem is synchronisation of flash and exposure time. maybe something you could try to fix? :D
gratz for the cam. hope we can see lots of progress
Right now my battery is almost deplated, so no tests are possible :-)
Your explanation is pretty strange. Lens can't change anything with syncronization between shutter and flash. Plus for me it looks rather random.
Like shutter speed estimation and flash have absolutely no relation.
Hi Tester,really pleased you`ve got the GH1 at last!..what`s the plan now though..do you still get feedback from other testers and also post the results of your own testing? :-)
What does?
* The time limitation (Europe) is over
* Pal -> Ntsc = ok
* Bitrate : no change
I've never gotten flash to really work either, but It shouldn't matter for video.
...Right?
Yes.
But it looks astonishing.
Camera without mirror and all related difficulties with sensors is not able to fire flash correctly.
I'll try experiment with "Lens not attached" hardware error setting later.
Yes.
I haven't used built-in flash on GH1 extensively, but in the few cases I did I haven't had a problem with signficant overexposure or underexposure in stills. These are your typical "social" snaps with very dark (not interesting) background or foreground fill in (darker foreground and brighter background, both interesting).
I do recall having blowouts when mounting an old Pentax AF-330FTZ flash. It will always fire at full power and GH1 seems incapable of adjusting exposure parameters on the fly in either program or manual modes. It would be nice if we could either measure "peak" exposure when flash is fired (so you could then set it manually) or even better, enable TTL mode. You are a Pentax hacker after all, so you may actually have the know how and interest in such "aerobatics." :happy:
You may want to go to one of the photo forums to figure out what you need to do. Here is a recent GH1 thread on using manual lenses with a flash.
http://forums.dpreview.com/forums/read.asp?forum=1041&message=35375449
I attached some flash pics below shot with my GH1 using the 14-140mm kit lens. I haven't shot any flash pics with my manual lenses yet.
Randy
You may want to go to one of the photo forums to figure out what you need to do. Here is a recent thread on using manual lenses with the built-in flash.
OK I'll see v1.32 improvements as soon as charger arrives.
But generally people think that flash do not work normal with manual lenses.
Flash is generally hard for software developers to figure out, as I see constant flash related problems across many brands.
I use dedicated Pentax PTTL flash normally, not build-in one.
I'll test how it works in manual mode on Panasonic.
If I red correctly, there is no pulldown for 24p but cannot playback clip in camera or it will freeze and need to remove battery for reboot. Is a solution being worked on to playback clips in camera?
Copied from the first post. Perhaps it might make sense to put this first in the post since it keeps coming up.
Major issues for today are:
Time limit for PAL cameras (done)
50/60fps PAL/NTSC switchable (done)
Audio Encoding bitrate low (done)
24p/25p native (done)
Third-party battery (done)
720p24 (720p25, so, partially working)
MJPEG 720p24 (skip frames)
1080p mud (have partially tested patch)
AGC for audio (research stage)
Video monitoring (research stage)
Isaac, you need to label the first post "Top secret - strictly private and confidential - on no account must you read this". That'll get it some attention.
You can't see thumbnails in video, soon as you do it freezes the cam.
For those who aren't in the "now", just d/l the ptool and load the firmware and read the descriptions each patch. They're labeled if they're working.
Here is photo of my small rig with GH1.
Our next target will be MJPEG compression.
It is useful and it really allows to test top SD card write speed.
I hope to buy today two speedy SD cards (Sandisk Ultra and other Class 10 card).
As soon as AC will be recieved I'll start testing.
Also very interesting is that all MN controllers are debugged and communicated using so called USB JIG.
This is just ordinary USB connection, but using special driver and special software to communicated.
Service software for GH1 uses same mode.
Having this software can save us amazing amount of time as we could rewrite small parts to just set values from USB.
Other possibility is to use file stored on SD card as we know almost all necessary functions.
