GH1 firmware research volunteers required
First results concerning HDMI output achieved.
I am able to switch between local LCD and HDMI monitor in playback mode using special routine working using GH1 menu (I use bracketing item now and few others for parameters adjustment).
In no way it mean that we will be able to provide live output soon.
As this procedure can't switch body to HDMI output during normal operation.
I still can't find info on the HDMI buffer IC. However, generally these have an output enable/disable pin. If you can find part of the routine that toggles an I/O pin, you might have found a clue at least.
Hi,
I wish I could do for the GH1, for the Canon 7D could.
Telling a short time would be very rich.
Just to make you $ 150 I'd give the restriction of video time.
Canon hd record time is 12min. Very bad.
Tens of thousands like me out ...
I think that you selected wrong address. Contact ML developers.
Plus time restriction removal is almost impossible to do in 7D due to no file spanning and overheating.
Sorry
Just a request.
Maybe he is one resourceful.
1 hour and 45 minutes, no problems (intermittent-intermittent), I can recorded.
Hi there,
I'm new here and didn't read the hole thread, but the search doesn't give any answer.
I own a hackable GH1 and the firmware is just great. Thank you!!
Now to my question:
Is it possible to change the maximum exposure time in video mode? The max I could set is 1/30s as described in the manual. But for FHD mode I'd like to set it to 1/25s for very dark scenes. Is this something that could be hacked?
Another question:
Is it possible to change the time the just taken picture is shown to the time the release button is still pressed instead of a fixed time?
Thanks again for your hack.
Hi Vitaliy,
for the case you meant me:
#1: On page 109 of the english manual is written that the shutter speed can be set between 1/30 - 1/4000 sec. in video mode [|M]. But I like to set it to 1/25 sec. Is this change possible?
#2: On page 34 of the englisch manual: Review: can be time between 1 and 5 sec or till the shutter button is pressed half way. I'd like to review till the shutter button is released. So if I take a picture and hold the shutter button down the just taken picture is shown till I release the button.
One more feature request:
#3: Is it possible to change the video modes a bit more? I'd like to have a 1080p25 (FHD) a 720p50 (SH) and a 720p25 (H?) and low bitrate modes 720p50 (and 720p25). Is this possible?
Is there a feature request wiki or the like?
I'd like to donate money in euros but the gh1-hack.info only accepts dollars. To whom shall I sent the money when doing it directly?
Thanks.
1) I really do not know. Shutter speed reversing is not finished. May be.
2) This is tough. It is low level stuff. And extra crucial. Buy remote shutter on ebay.
3) Don't get you. Do you mean all three in one setting?
I am working at adjustable modes. We'll see that could be possible to make here.
You can donate in any currency, paypal will convert them :-)
Hallo Vitaliy.
I hope the best.
But in video mode not the real shutter is used. It's just the exposure time. (I'd like to have 1/25 sec for p25 avchd mode in very dark scenes.)
Ok, this is not that important. Just would be a nice handling I'm used to from other cams.
I think the adjustable modes is what I want.
I thought about the 4 different avchd video modes for which I already can adjust the bitrate with ptool3. (FHD+ SH, H, L)
For instance this would be nice:
FHD = 1080p25 high bitrate
SH = 720p50 high bitrate
H = 720p25 hight bitrate
L = 720p50 low bitrate (or 720p25? low bitrate)
or similar.
BTW. ptool3 works flawlessly with wine under Linux (ubuntu) too!
Have a nice time.
Hello all, I've been reading the GH1 forums for quite a while and finally took a chance on a WE0F (June 2010) GH1 but struck out and got 1.34 firmware, so I'm returning it in 48 hours. While I've got it I'd be happy to try a firmware dump if there's any known procedure to try?
I read on another thread that Vitaliy said he preferred not to answer if this could be done until early October...?
I'm intrigued as to how a firmware downgrade is prevented, from a technical pov - is it a
version identifier (checksum?) in the .bin file which is compared to the currently installed
firmware?
Is there any way that the 1.32 firmware can be modified so that it's identifer appears to be
1.35 (or higher) so that the 1.34 ver then sees it as newer and allows it to be installed?
I followed a thread on another forum where people had successfully downgraded their Pana
ZS3/TZ7 from firmware V1.2 to V1.1, despite the official info from Panasonic that it couldn't be done... (http://forums.dpreview.com/forums/readflat.asp?forum=1033&thread=32602197). Does this give any clues / ideas?
This would simply be a hex-edit on the .bin file of the original firmware. Don't think that would be too hard.
Also, you could just load the original fw into ptool, then only click the version increment and up it by whatever you need and then save it and load it. ;-)
firmware?
It is actually very easy to implement. Vitaliy's patch will now change the version number in all places where it was needed for 1.2 and 1.32.
All Panasonic had to do is put a version check in one more place and implement this check in 1.34.
Now the version 1.35 created by Ptool will surely fail such a test and will be rejected or contemptuously ignored.
No, the firmware for the G series always checked the version and would only allow upgrades to higher ones. To overcome this limitation Vitaliy created an option where the Ptool generated firmware would be seen as version 0.0, thus allowing any older versions to be used for the upgrade.
i think the new 1.34 firmware will also check something other than version to allow update.
that's why you change the version to 1.35 or higher using Ptool, the 1.34 firmware still not allow you to update.
and the 1.34 firmware has not been released to public yet, so Vitaliy may not have a copy of 1.34 firmware to analyze.
