GH1 firmware research volunteers required
I would still need to put the SD card in and out, press play to start firmware upgrade, refocus camera, etc etc. Essentially I need to gather a way to clamp everything down tight... or figure a better way to tether the actual test screen to the camera setup... which may be easier. In any case, the numbers are either accurate or pretty close at the moment. I'll look into though.
For now, I think I'll finally get some sleep. ;)
I'm not sure where to request this so I am asking here; if this is the incorrect forum then please move it appropriately. Could you create a tool to export the relevant camera settings such as: film mode settings, overall bit rate, limiting bit rate, etc? This could help testers see other testers’ settings and replicate any tests using the exact same settings. Thank you.
Hi, i'm new from France and i wanted to tell you that that's a very interesting project, i was wondering since a long time if somebody would hack the LUMIX G serie (like what happened with the CANON powershot models for example) and YOU are doing it! Great, i know nothing about programming but i just can maybe suggest you ( i don't know if it's the right way to do it here?) to try to improve two things on the G Lumix serie with manual lenses:
1) the activation of the zoom function is cumbersome because you cuurently need to press TWO buttons, so implementing in the hacking tool the ability to assign for example this function to the Function (Fn) button would be a great improvement when focusing manually with this zoom.
2) this zoom has several ratio increments to increase the magnification of the focusing area, but with some long focal lenses, some added lower increments would be great because the minimum increment currently implemented is sometimes TOO MAGNIFIED and the focusing is then difficult cause the image jitters too much!
If you can consider a way to implement this i think many users of manual lenses (for photography or video!) on G series will appreciate!
Good luck in your research and hacking work, guys :o)
You've got that exactly right. This subforum is only for testers and Vitaliy to exchange information with each other. No other posting is allowed.
General discussion takes place one level up, in the GH1 Hack forum.
Vitaliy, here's something to consider on the AVCHD 1080/24p->720/24p patch: we know that currently it's just extracting the upper-left quadrant, cropping that to 720p and done. A user named "VideoDSLR" has suggested that you explore trying to instead extract just the center of the image instead of the upper-left, without scaling. By doing so, it might make many more c-mount lenses usable without vignetting.
If there's a sensor adjustment parameter similar to the m4 Adjustment 7 & 8 on the 720p modes, but for the 1080 sensor settings... then that might just me a matter of plugging in the right value to shift the frame over.
Small preview of PTool 3.40d (only part of overall interface).
Any professional icon authors can contact me by PM or email, as we need some good 16x16 icons.
Target problem: banding
Info: noone of checked movies had full range (0-255), so may decide that firmware have limiter for Y (16-235) and for UV (16-240)
That's normal, 16-235/240 is known as 'studio levels' and is used by most (all?) video files that encode as YUV (YCbCr). Editors also expect that.
However, some cameras like the HV20 will record up to 255, ie. they record 'super whites' (which are also valid & desirable). Do any of the GH1 files you've examined show values greater than 235/240?
no. all in TV broadcast range.
that normal when you have zebra and at filming can see over/under exposed areas, but that is also source of image banding (if you do't knew/saw that problem) , that persist on GH1.
inaccurate algorhytm, which can be made more correct in 2 ways :
1.full rewriting = think that not very wanted by team;
2 - simple change limits of software limiter from 16-235/240 to 0/1-255 (1 as possible division in algo to that value, and divide by 0 not desired) <- that is more real way ...
an one more note - there is more than only superwhite and superblack, but much more colors (that not fit in non-negative rgb values at all) ...
Posting here as it pertains to one of the core requests on the tester page. Please move if I have mis-posted.
Ok, just wanted to share some info. I was doing some serious networking and tossing out a wide net to try an find an in with Panasonic. I ended up in contact with someone at Panasonic who was very open and helpful. She doesn't work in the divisions we are seeking, but she gave me two possibly very good contacts. Here are some excerpts form our conversation: (Details omitted to protect my resource)
"Anyway, as to your question - I am the (Job Title Omitted) at Panasonic in the web & internet design department so I have no technical knowledge of our products. I passively scanned the thread you referenced and cannot say that I know exactly what you guys are trying to do... SO I won't say that I support your efforts. ;)
However, I can try to point you in the right direction.
Here are some contacts that may help you out:
"***** is a Technical Service Representative II @ Panasonic Customer Call Center; ****.*****@us.panasonic.com- He's a really nice guy and friend of mine who may know what kind of info you're looking for."
Second contact: " (Title Omitted), Imaging Products; ****.****@us.panasonic.com - He's a top guy in the Lumix group who also may be able to help you."
Anyway - that's about as much as I can do. I really hope you figure things out. I think these would be your best contacts based on what you told me.
Best of Luck,
So, it could be nothing at all, but it could be very significant. I got the feeling that she thought these contacts would be receptive at the very least.
So, what I would like to do is find out who amongst the core supporters would be best suited to make contact with these people. I don't want to burn these contacts, and I would prefer someone who is well qualified to approach these contacts in a tactful manner that would possibly get a favorable response.
I can PM the full details of the conversation including the contact info and names to someone who is willing to follow these leads with care.
I have a couple other irons in the fire that I am hoping to hear back from mid next week.
- Greg
