philip bloom
wonderful Job Tester 13...my gh1 is now out of the dusty cupboard and back in my hands!
GREAT--I only have class 4 cards. I have no problem using higher bit avchd.
Hrm, well.. for starters there could be differences is how the sensor is aligning with the chart in each shot, which could cause abnormalities. Even though I was being careful with the tripod... pretty much stepping on the ground near it would cause a change in the fine line distortions. Also, obviously the MJPEG is conciderably softer since it's upressed in camera, so the AVCHD has more fine detail to exhibit aliasing on.
Okay, I just loaded up PTool using the "D" settings, but I modified the buffer to be 60, so it's as big as the maximum bitrate. Then I took it to the forest/lake park with some ducks. Shot a whole bunch of 1080/24p native mode. It's absolutely awesome. This patch is the real deal, and I totally love that there's no pulldown! I shot scenes that the GH1 has choked on before, including high-shutter speed fast pans past a forest of pine trees, and the new "D" settings handled it just fine. It's much sharper than it ever was before.
I also tried the MJPG patch, but I can only get a couple of seconds of recording before there was a card write speed error message. Using a Lexar Platinum card, which is only rated at Class 6 but CrystalDiskMark rates it at 9.7 megabytes/sec. MJPG wasn't really useful at this point. I'll have to get a Lexar Professional card to do more testing.
The AVCHD mode did run into a write-speed problem once, but only once out of 30 clips.
I also shot a chart; I'll report back on that after evaluating the footage.
Yes, it's just you -- because shooting the same chart, there's not a doubt in my mind that the AVCHD is a far more "correct" representation of the image. The MJPG looks to be some sort of uprez.Here's what I'm noticing about that chart, and maybe we just need to see another resolution chart with the same comparison: the AVC-HD exhibits more aliasing than the Photo JPEG material.
Is that just me?
I can't tell you just how good these ducks look. I remember being so flummoxed by the seagulls I videod, some of them looked pretty good and some were mushy, and I had to wrestle with the sharpness and contrast to try to get any detail on them. Well, let's just say that it ain't that way with the ducks!ABout time! You took too long! Please up some stuff.Thanks for going out into the field and reporting.
I'm already searching the online tests. It's leading me towards the Lexar Professional, until the new Fuji cards drop in November.Okay, so basically when I get a GH-1 again, I need to grip two of the highest class cards out there. Good to know.
Can't do a fully proper one until I get a faster card that'll support more than a second or two. But right now, as of what I've already shot, I don't really see much a point in continuing with the MJPG.Thanks Barry_G. Can you do an MJPEG vs AVCHD test for moire/aliasing? Something quick and obvious?
Well, for me, it's a case of a window of time opening up, combined with a perfect storm of the patch hitting the right note at exactly the right time.The excitement is clearly building with Barry and Philip getting into the action!!
It's a whole new camera. And it's a really, really, really good camera!
What exact settings are you using? Let me try those, but it sure looks to me like it's uprezzed 720p...Are you sure? Mjpeg at 70mbit on 720P is gorgeous, and different than AVCHD. They just look different!
Pappas
