killmaster
Hi There,
Based on recommendations from this forum I purchased a Canon T2i and Olympus LS-11. I'm very very happy with my decision. I've been experimenting with sound and am thoroughly confused however. I set up all my microphones and tried some tests to determine what setup I will use. I'm starting out doing interviews and acting so voice is the main concern.
When I plug my lavelier directly into the LS-11, it already sounds great, though I have to crank the record volume up to 8 or 10. If I go through my preamp, I get much more sound but also much more environment noise. I turn to volume down to adjust and its turns out that it sounds to my ears almost identical to cranking the volume up during recording. Another mic (Rode NT1A) sounds way better through the preamp while my Shure SM57 actually sounds much better not using the preamp. I'm really confused on how to think about this. I don't want to just trust my ear. I want to know I'm getting audio I can use and edit with successfully. I have a large variety of mic types and each seems to have noticeably different responses from each other. So how best to think about all this when you are starting out?
here are some basic questions that came up:
1) should I use a preamp no matter what?
2) if I use a preamp, should I still plug into the mic input or should I plug into the line input on the LS-11?
3) what's this about balanced and unbalanced? How can I know? I know the cables I got are supposed to be balanced.
4) I assume I should record PCM for best quality (shows up as WAV in the menu when I select PCM)
5) For my livelier (AKG CE10), should I use phantom power if the mic manufacturer says it can take phantom power or not? Sound about the same to me either way.
6) Is the Olympus "Plug-InPower" the same as phantom power? From what I can gather it is the same.
7) Is there any reason to try and record line in on my T2i instead or in addition to recording externally?
8) If I just record externally and don't shoot anything over 5 minutes in length, is sync going to be a problem?
If there is an article that spells this stuff out for newbies, I'd appreciate a link. I looked but couldn't find anything that was layman enough for me to understand...
thanks!!
greg
thanks!!
greg
