getting back default scene file setting
iknowthings
I uploaded 4 scene file packages to my SD card. I want to replace one of them with the default scene file. How do I go about doing that? Do I have to download them from somewhere or are they already in the camera? Thanks!
That's actually quite easy.
Go to edit the scene file you want to restore to its default, scroll to the bottom of the menu, and use the INITIAL setting, then select SAVE to store the restored settings -- if you don't do that, the camera will revert back to the last SAVEd or loaded settings.
You can also write the settings out to the SD card using the CARD FUNCTIONS menu.
