starcentral
Yes before I decided to jump over to a higher end monitor and decklink for color work, I was just using regular monitors in conjunction with the DataColor spyder color calibration system which creates a color profile managed by your computer operating system and applies it when your computer boots up. As you say, this uses the computer's video card system to apply the correction that results from the calibration.
Once you go to a separate card like the intensity or decklink it allows you to monitor the output as a 10-bit quality video signal and the color is not managed by the operating systems at all. It is a pure TV/video signal coming out of your machine - but the software (Final Cut, DaVinci, et.c.) must allow the option of being able to select that monitor as a monitor output but most do nowadays.
The color calibration in this setup is usually managed through a 3D LUT loaded into the monitor itself, or in a LUT box like eeColor that goes in-between your computer and monitor. You'd use software like lightspace or color navigator to calibrate your monitor with something like an X-rite i1 to create your LUT for you.
This stuff takes a bit of time to wrap your head around, that's for sure.
